hi all
i have a 96 vitara v6 2.0 5 door, she finally purrs like a kitten and im really enjoying the old girl, however she is super heavy on fuel.
on normal commuting i get less than 320km for a full tank, i checked for leaks, odours etc and found nothing, she is also pretty weak for a v6
but she sounds good, purrrs along the freeway
any advice / suggestions ????
regards from here in South Africa
Deon
Telling us less than "320km for a full tank" tells us very little - we need to know how much fuel you're putting in the tank.
Telling us "normal commuting" tells us even less - is what's normal for me, normal for you?
The way to do a fuel consumption check is to fill the tank, note the level in the filler neck, zero the trip odometer and drive - the next time you fill, fill to the same level as before, note the quantity of fuel, note the mileage, reset the trip, and repeat - do this for two or more cycles and get the average.
Phil - I don't think the SV620 was ever released with an OBD2 compliant injection system, the Africa market models didn't even have an O2 sensor, they run open loop 100% of the time.
Phil - I don't think the SV620 was every released with an OBD2 compliant injection system, the Africa market models didn't even have an O2 sensor, they run open loop 100% of the time.
WoW! I missed the location completely..
Revise my suggestion, ignore the fuel trim..
.... Philip
