Greetings forum members. It has been quite a while since I posted here, surely some of you may remember me from days past.
Being the creative individual that I am, I recently put in a bid to build a multipurpose farm vehicle. I designed one using of course the Suzuki power train, a dump bed, dual rear wheels, all mated to a tubular frame structure such as in used in sand rails and dune buggies. I call it the Dumpbug. I won the bid and will start this week gathering up the required bits and pieces. First, I am looking for a Suzuki 4X4, pickup style, with F5B engine, and lockout hubs, preferably in the Visayas region. I don't care what condition the cab is in, but would prefer one in somewhat running condition. CHEAP! ;)
The Dumpbug will look somewhat like a John Deere gator XUV. (Google it) Here is the specs I provided the customer;
Custom built Suzuki utility vehicle
Price P250,000 complete
Engine and electrical
Engine model Suzuki F5B
Type Overhead cam, 6 valve
Cylinders 3
Horsepower 29
Displacement 550 cc
Torque 32
Lubrication Full pressure, spin on filter
Cooling system Liquid
Air cleaner Dry replacement element w/ remote intake
Battery 600 CCA
Alternator 35 amp internally regulated
Lighting Full headlights, tail, turn, stop, utility
Fuel system
Capacity US gal 9
Consumption at half load Liters per hour 3
Fuel pump type Electric, with external fill
4WD
System type On demand
Front differential Locking hubs
Transmission
Type 4 speed standard w/ low range
(8 gears forward, 2 reverse)
Clutch Manual dry disk
Brakes
Front Hydraulic disk
Rear Hydraulic drum
Park brake Rear mechanical drum
Suspension and steering
Front Independent McPherson strut
Rear Semi independent straight axle
Travel front 6 inches
Travel rear 4 inches
Turning radius 16 feet
Steering type Rack and pinion
Hitch
Front 2 inch receiver tube
Rear 2 inch receiver tube
Bumpers 4 inch heavy channel and steel tubing
Occupant protection system (ROPS)
Tubular wrap around structure 2 inch schedule 40
Grab handles Front, top, side
Seat belts 3 point shoulder harness
Instrumentation Speedo, temp and fuel gauge, oil pressure and brake warning lamp
Electrical accessories Cigarette lighter and horn
Ground clearance
Front 12 inches
Rear differential 8 inches
Lowest point other than rear differential 12 inches
Dimensions
Length 120 inches
Width 54 inches
Height 76 inches
Wheelbase 84 inches
Weight 1800 Lbs.
Seating capacity 2
Seat type Bench
Storage Glove box, trunk
Towing capacity 2000 Lbs.
Payload capacity 1600 Lbs.
Maximum safe speed 70 KPH
Cargo box
Material Steel
Dimensions 54 X 60 X 14
Capacity 23 cubic feet
Dump Electric over hydraulic
Tailgate Hinged at bottom, easily removable
Sides Hinged at bottom, easily removable
Front Fixed, full headache rack
Tires
Front 6.50 X 13 deep lug traction
Rear (Duals) 6.50 X 13 Tractor lug
Color Customer’s choice
Warrantee 12 months
Appearance and specifics
Vehicle will look much like a John Deere XUV 4X4 Gator, with added heavy bumpers, dual rear wheels, windshield, top, and a longer cargo box. It will be slightly taller, longer, heavier, and narrower, and have tires and gearing capable of Philippine highway speeds.
Some specifications are estimates only, actual unit may differ slightly but will be similar to specifications listed. Customer has many choices concerning actual specifics, as this is a custom built vehicle designed to suit customer’s needs.
All mechanical parts used will be surplus parts readily available at low cost in The Philippines. Vehicle will be designed with ease of service and cost of repairs and maintenance in mind. All components will be strategically placed so as to make replacement easy and straightforward.
All steel will be new. All steel will be oversized for application, ensuring years of rugged use. All new steel will be painted with rust inhibitor and painted with epoxy paint of customers color choice. Vehicle will have a full heavy frame and rugged front and rear bumpers designed for extreme heavy use. Rope and chain hooks will be strategically placed so as to allow easy hooking up of towed loads and tie down of payload. Cargo box will be considerably larger than John Deere and Kawasaki counterparts. Skid plates will be installed under chassis to prevent damage from sticks, rocks, stumps, etc.
Vehicle will have full electrical system complete with headlights, tailights, turn signals, wiper, cigarette lighter, and horn, and will be street legal. All lights and electrical devices will be enclosed to protect against damage from brush, sticks, rocks, etc.
Vehicle will meet safety requirements applicable to US utility vehicles, and will have adequate rollover protection to protect properly seat belted driver and passenger from serious injury in the event of rollover with fully loaded vehicle.
If anyone knows of a multicab that may fit my needs, please let me know ASAP. I will be traveling to Cebu early this week in search.
Thanks, and regards,
Larry in Dumaguete.
