I swear this pile of @#$^%$ is determined to fight me every single step. Seriously, nothing went right today. Finally, a few parts showed up yesterday evening. So I thought today I might be able to get the torque converter and flexplate bolted together, as well as install the brand new crank position sensor. So far I've managed to loose one of the bolts. For the record, I should have waited to install the starter/alternator/right side exhaust until AFTER I had the TC and flexplate finished up. As it is, I had to install another elbow in one arm, then reach in from one side while trying to look up through the little inspection plate to line everything up, then use the very tip of my fingers to try to spin the bolt. I thought I had the bolt in about 1 turn, then grabbed my little ratchet to try getting it in farther. Of course that's when Murphy showed up. The ratchet dropped down and smacked me in the face. I collected myself, found the wrench and went back in, then I couldn't find the head of the bolt. It's GOTTA be right there, why can I find it? Go in by hand, and realize the bolt is missing. Gone. As in vanished. No can find it anywhere. Not in the car, not on the shop floor, not in any of the corners around the shop. I looked all over, my wife looked all over, my son looked all over. That dang thing is gone. And at this point the only place I can figure is it somehow managed to fall into the bellhousing. Which means the engine comes all the way back out.
And that might be a good thing because I can't get the CPS to go back into it's hole either. The entire reason I bought a new sensor is that the o-ring is unavailable separately, and certainly NOT part of the 'complete' gasket kits that I purchased. Yes, I have two 'complete' gasket sets, and neither of them is actually complete. Anyway, the o-ring on the replacement sensor is just NOT going in the hole. I pulled the o-ring off and installed the sensor just to make sure, and that went just fine. But of course it won't go into place with the o-ring installed. Lots of oil on thing, try to get it in, wiggle it around, push hard with a block of wood...remove, oil, install...push..remove...repeat 18 times, realize at some point that the o-ring now has a little slice on the edge from f-ing around with it. Add a little grey sealant and try a few love taps with the wood block. Still nothing. And of course I've already torqued the front pulley/harmonic balancer in place, so that's not coming back off without a fight.
At that point I was ready to send the hammer through the windshield, so I decided it was time to quit for the day. Seriously folks, If I ever get this one together I'm selling all my Suzuki's and never going to own anything again that doesn't have dealerships in the USA. ARGH!!
UPDATE: Apparently there is JUST enough room in the front axle mount for that missing bolt to drop down inside.
And, I just checked on my order from SSG.asia, and it looks like almost all of my order is cancelled, including the last of the bolts I need to finish mating the engine and transmission. Anyone have a parts pile they'd be willing to look through? Specifically I need to find one more of the TC to flexplate bolts, and one each of the longer and shorter bolts that hold the engine block and trans case together.
