Hey guys, new Sammi owner here trying to sort out some issues. I have a 92 EFI 2 WD model, the temp gauge does not work, needle just sits there even when fully warm - would the order of troubleshooting be:
1. check the wires from the sending unit to the gauge,if that doesn't fix it...
2. replace sending unit,if that doesn't fix it...
2. replace cluster with working temp gauge
Thanks for the help -
start by grounding the wire at the sensor, gauge should nor read hot..
If not, check wire and gauge, if yes check sender
... Philip
