Hi every one.
I have a 1987 tin top. Has 5.13 gears, locked f/r, stock tcase, stock trans, the 8v tracker motor. I have a mind baffling question for you all. I just rebuilt my tcase and trans with all new bearing. I had a real bad noise that i thought was the tcase so i replaced the bearings and seals and it was still there. So i thought that it was the trans, pulled it out rebuilt it and still the noise was there. So after a little investigation i found a real bad noise coming from the tcase. So i tore it apart thinking that it was the gears hitting the side of the case but no metal shavings. the gears all look good. Have no idea what the cause of my noise would be, CAN ANY ONE HELP ME!!!! IM STUCK ON WHAT TO DO:mad:
