Hi All,
I have an issue opening the drivers door only. The emergency key will not turn clockwise to unlock from the outside. The door cannot be opened from the inside either.
I have managed to remove the internal door card to access all the cables and actuator etc, but still cannot undo the door.
I have checked voltages getting to the actuator and all is normal. The fault appears to be a stuck/faulty actuator or seized mechanism in the actuator etc.
My question is, is there any way to open the door now I have access to the door internals. Ive tried to rotate the metal pivot that the lock bars move, but this still doesn't release the lock. I cant remove the actuator as its locked to the door lock latch.
Any ideas would be great.
Kind regards
