So I have an '05 Forenza wagon, 28k miles, manual. Since I bought it with 3800 miles on it, it has had problems coming to an idle when coming to a stop. The RPM's drop past the usual idle of 900 - 1000, and often drop so low (below the 200 mark) that the engine shudders and the lights dim. The car has never died, but it's come close.
I had the high-idle problem early on, and had the re-flash done. That took care of the high idle (although it did it a few times after), but it has always had this issue when the RPM's wind down.
It's probably 60% of the time that it will do it. Hot or cold, it still does it. It's done it at high altitude and at 2000 feet. It will do it if I hold the clutch in, or put it in neutral. I can't pin down anything, and the car has NEVER thrown a code.
I've had the car in 6 times for this issue - and of course it doesn't do it during the 10 min. test drive by the mechanic. They won't do anything until they physically see the problem happen. I called Suzuki Customer Service, and got them to authorize a loaner for next week, so hopefully the mechanic will experience it.
Have you guys seen this at all? Any suggestions on where to look? Suzuki won't do anything until they can recreate the problem, but once they do, they're not going to know any more about it than the details I've given them. I've been to 3 different dealerships, and I know this isn't a Suzuki-designed car, but I'm not so far impressed by how Suzuki handles a problem. Every time I have a day off, I arrange to give up my car for the day... and nothing results.
