I'm looking for some help.
My son pulled the spark plug wire off the car, while it was running. We put it back on, but the car wont start. We put new plugs, new wires, still nothing.
It turns over, but wont start. Any suggestions? This is my only vehicle, and I need it running! Any help would be appreciated.
What year and engine?:huh:
Have you checked your fuses? Particularly the ignition coil fuse under the dash? With your key in the on position (no start) do your dash lights work??
Are you getting a spark? pulling the lead off a running engine isn't good for the igniter so you may have killed that. If you have a 5-lead distributor cap then it will be mounted near the coil, if you have the 4-lead cap then its built into the distributor assembly
