Hello!
On my Suzuki Vitara Hybrid 2021 the radio shows only the radio frequency (ex: 102.1) instead of showing the radio station name. Is there a way to make it display the name instead of the frequency?
Thanks a lot in advance!
Read the handbook to see if it can display station information as it will depend on the radio supplied in your region.
You need to make sure that RDS is available in your location because that’s what carries the data which includes station name etc. if you’re sure you’re in an RDS location then try enabling “Alternative Frequency Search” which will find the strongest signal for the station you’re trying to listen to. You may find that you’re not on the best signal and not receiving the RDS data.
If it still doesn’t work, you’re only option is to consult a dealer. You’re still in warranty I assume.
