Hello,
I have a problem with a water leak on my Vitara, which seems to be coming from the sunroof. The water ends up inside the car through the dome light (where is the sunroof commands), fortunately in small quantities.
I am trying to determine first if it is not a problem of clogged drains.
I noticed that there was a channel between the two parts of the sunroof, which guides the water to the sides. Then we see what appears to be the entrance to the drain.
Could someone confirm that? I'd rather be sure before pouring water in!
On the following photos you can see:
1. The channel which leads the water to the sides.
2. The presumed entry of the drain.
3. Have I surrounded what appears to be the inner shell? It is certainly through this shell that the water circulates to the ceiling, but I do not quite understand how.
Thank you for your help !
