my Suzuki sx4 2008 has 95,000miles with the shifter position at "D" engine rpm goes up but the transmission does not gear car speed slow down I keep triyng to accelerate rpm goes up
after sometimes I feel the transmission start to gear and is function okey
this problem happen not all the time is intermittent any idea what could be ?
i will appreciate any suggestions thanks in advance
Hello cachorro,
Not sure I fully understand your question but I'm interpreting that when in drive (D) and you accelerate the transmission is slipping resulting in increased RPMs but no transfer to drive shafts so the car does not accelerate.
Not sure of your location (USA or Canada?) therefore not sure if powertrain warranty is applicable. Probably not if 95000 miles and not kms.
Has your SX4 had a transmission fluid change (it should be due its second perhaps third change if you do towing)? Is the fluid level correct and Dexron III used?
Hopefully, someone else on the forum will be able to advise.
i am located in Canada yes seems to be that the transmission is slipping but not all the time
I check the fluid level and it was a bit low I added some dexrom III i'll check to see what happen
thanks TegsPal
