Hi I have a Suzuki swift 1.3 gl07 plate and every time I start it up in the morning it makes a horrible squeak noise for a little while until it warms up it only makes the noise when I drive it and lasts for about 5 minutes any help please :) x
Check the tension of the alternator drive belt. A loose belt will cause those exact symptoms. ;)
Replace the belt if years old, is also my suggestion as long as you are in there.
It's tricky to replace, needing tools and tensioning when installing or simply tightening.
Yes, more than likely the belt is the issue.
