If you took the time to explain what it is you need help with, you might actually get a response ...
Please also refrain from making new threads to ask the same question.
Discussion Starter · #4 ·
I'm looking for a drawing of this ecu, which pin goes where for me, only a Monitor coupler Diagnostic switch terminal pin I care where it goes .causes an error code to flash I'm asking for help with this.
Not all ECUs have the monitor coupler/diagnostic switch terminal, the ability to flash check engine codes was a feature of the pre OBDII ECUs, the probability of your 2003 ECU having the monitor coupler is quite slim as Europe required EOBD/OBDII compliance on petrol engined vehicles from 2001.
