Driver Door locks when in unlocked position: When the inside button is in unlocked position, and I close the door from the outside, it will occasionally lock from the outside. Locksmith said the parts may be worn down. Yes, I do keep an extra spare key. Has anyone else experienced this? Solution?(Suzuki Swift 98 manual trans)
Find a different locksmith - I suspect a bent actuator rod, or the rod is out of adjustment.
