Ace socket: can any one give me an heads up which fuse supports the old fag lighter I have tested all the fuses and they all seem to be ok but still no power to the socket? Any ideas.
Discussion Starter #2
Suzuki swift 2019
Acc socket: update to my last post: my swift is a 2019 and I have no power to the ACC socket ( old fag lighter) I have checked all the fuses under the bonnet they seem all ok any one know if there are other fuses
under bonnet fuses are only for major engine bay components.
15A fuse in fuse box drivers side kick panel under dash, fuses are labelled on the cover. Look up above the pedals looking towards the outside of the car, Cover un clips. Should be (depending on model) located there.
Check your owners handbook, in the index under "fuses" it will even tell you what fuse is what.
