Hi I have a Suzuki swift 2006 3 door and recently I have been having problems with my brakes going extremely soft and needs the pedal to be pushed very low for any braking to happen. This only happens when my ABS kicks in and this happens an excessive amount of times. About a month ago I got my car serviced and bled the brakes and replaced the fluid but on the service the problem didn't happen so the mechanic didn't know what the problem was. I had since taken it back and he has re-bled the brakes again and it was working fine. The problem Has started happening again but it is intermittent and the brakes will go soft about 50% of the time that the ABS goes off. Does anybody know what is causing the excessive ABS and the low pedal fault?
