So all off a sudden i noticed the brake light warning in the dashboard suddenly flicker.
It seemed to "lit" if i turned sharply to the left, but then "turned off" or flickered when i accellerated. After awhile it went off, and back to normal. However when i was about to park in the basement of the parking lot, it was lit again. Also came back when i turned off/on ignition.
After a day at work, and back to the car, i turned on the ignition and the light was off.
Fast forward two days, and the light is flickering on and off at different parts of my journey.
Tried pumping the pedal before ignition until it went stiff, and when i turned on ignition it slowly depresses as expected.
Any tips?
I am wondering if it might be the main CPU going bad. As i just had an issue with the engine light, the OBD reported two faults. 1. ABS problem 2. RPM sensor. However after theese were "cleared" they have not come back.
Any tips?
