Where can I buy the following spare parts for Suzuki Samurai motor vehicle (F8A model);
1. Timing belt
2. Main Bearing
3. Connecting Rod Bearing
4. Overhauling gasket
5. Piston Ring (standard)
6. Carburettor Assembly
7. Ignition Coil (1 set)
8. Starter (assembly)
Where are you located? You can get F8A parts from 4WD Products (in Australia) and they do ship worldwide.
Are you sure standard rings are what you need - I can't see a 40 year old engine needing a rebuild and not having worn bores - not unless it's been lying parked for much of that time.
By the way - that's either not a Samurai, or not the original engine.
