Please help! Change new pump and fuel fiilter, now when I turn the ignition key everething seems to be fined engine turn...but I cant ear the pump working and there is no spark..no fuel at the engine..found burn fuel pump relay and change it for a new one.
Normally you should hear the pump priming for 3 seconds when you turn the key to the on position - it may be more difficult to hear when you are cranking. But, when you are cranking the car, do your dash lights work (battery light, check engine light, etc)? Have you checked your fuses? The ignition coil fuse runs the fuel pump relay, etc., and as you had a problem there, it is possible that the fuse has blown. If your dash lights are working, also confirm that your check engine light is on with the key on, and off when you crank the car.
As the ECU governs spark in your car, and if it thinks there is a spark problem, it will stop fuel delivery as a safety measure.
