My 2010 Suzuki has two front wheel bearings go & two front ball joint assembly's Big Bucks . I now have a idle problem & thought I would take it to a garage to get it checked which probably will be more Big Bucks . Checked for a solution on goggle & it was put key into ignition turn one but do not start turn off & redo put Emergency brake on & hold brake Pedal down start car & idle reset will be adjusted by computer . Another one was my car door locks kept cycling on & off cured that by ignition on open door close door turn off ignition & problem fixed . Please if anyone Knows more of these secret solutions where can they be found because little remedy's like that will save a lot of money P/S some repair shops my also charge the Big Bucks for a simple secret solution .
never heard of that idle relearn procedure before, the factory one is disconnect battery 10 mins, reconnect, ign on, DO NOT TOUCH any pedals, wait 40 seconds, start.
