Hello Everybody!
Last January I bought 1989 Samurai for hunting car and after 1 month every time I started the engine it had a similar little noise like you start car while it is already running. It started little by little and then it was getting worse. One time I noticed that the starter was loose and one bolt was missing. I replaced the bolt and the issue was still there. I thought that I have to replace the whole starter and so I did. I noticed that the old starters teeth were little worn out. After the new starter the engine started a bit better but the noise was still there and it was getting stronger again. When I was replacing the new starter I saw the flywheel and there was few sections with it's teeth's witch were worn of.
Last two times I started the car and it sounds like the starter's teeth's doesn't touch at the flywheel at all. And it wont start.
So my question is: What the hell I suppose to do? Do I have to find new flywheel and does anyone know where to find those? Or is there something with the starter that I didn't realize?
Help!
And sorry my English
Help!
