Hello everybody,
I have a 2004 Suzuki R wagon that has uneven braking pressure, in fact to be more precise the right rear wheel cylinder does not move when the brakes are applied. They have been bled or rather no air appears to be issuing from the bleed nipple as there is also no pressure there. The wheel cylinder pistons move freely on the inside of the cylinder. Could the ABS be playing havoc here and if so why as the ABS warning light not illuminated?
Thanks for your help...
Check the flexible brake hoses for damage/deterioration
and confirm the steel lines are also clear, not uncommon for them to block due to corrosion.
