1 - 10 of 10 Posts
Hi
I am new to this forum and really love my car. I had an engine swap to a manual Liana/Aerio from 1.3 to 1.8. The power is so good. I was running the old 1.3 ECU. Finally found the ECU ( Picture attached). I have its wiring harness of ECU and the auto gear which I want to shift to. The problem is that I do not know which Gear card/smaller ECU to go with.
1. Please guide me which card goes with this ecu and gear( the gear has four connectors. One main grey colored grip. two solenoids and one other)
2. I need the wiring diagram for both the ECU'S. i.e. main ecu pic attached and the gear ecu which i dont know about. the diagrams pinouts etc
Please need your help. Would be really thankful.
Sal
first of all, what are you asking? are you trying to find an ecu for the 1.8? or for an automatic transmission? or are you trying to fit an automatic transmission to your engine? relative years and models will help too as there is a very big difference in ecu's between years and getting them, to communicate with each other can be problematic.
Reactions: sajid84
Thanks for the kind reply.
Well I have this ecu which i have attached a picture of. I do not have the gear ecu, as to my knowledge there are two ecu's. one is the main the other one is the gear ecu; from which the wiring goes in to the main ecu and gearbox
i do not have the schematics of this ecu and do not know which gear ecu goes with this ecu.
I am attaching the pictures of the gear box which i bought from the market and installed it which had a perfect fitting.
So what I need is:
-information on gear ecu which goes with this one
-schematics for both of them
-is this ecu vvt or vvti?
Really appreciate that you took out time to help me out.
Thanks a lot
OK
Hi to all
it seems I have asked a wrong question. All questions have been answered now. One last thing is if somebody knows that which TCU goes with CA M1.8 ECU? either its 5P or 5D or anything else?
Your help would be highly appreciated
Hi @sajid84
Can you please let me know how were you able to fix the ECU? and did you feel any more power after fixing of m18a ecu?
he has the ECM for the 1.8, i.e. the correct ECU for the engine.
Reactions: sajid84
Discussion Starter #9
Hi @sajid84
Yes
actually i got the ecu CA 1.8 ecu paired with 5D TCU for which i have to change the internal wiring with dashboard out of the way. The gear has 2 pulsars. It is running fine and with great power. just a thing that it is just giving me an average of 6.5/L
dont know what to do.
Does anyone know what colour the injectors come bundled with 1.8 aerio? I have the yellow ones installed
1 - 10 of 10 Posts
