Hi,
I'm a beginner with car engines, learning as I go. My 1.3 ignis (manual) engine light came on and mechanic tested and said it needed new plugs, leads and coils. Car was running but sometimes pulling on acceleration and a little bumpy when idle. I removed and replaced the old spark plugs to test if I could do the job myself, car started fine. However, I removed one of the old plugs again to check the part number and when I replaced it this time the car wouldn't start. I tried a few times and the engine made a strange, slightly alarming noise. I removed the spark plug and found oil at the tip of the plug and a little whiff of white smoke came out of the engine - eek! When I replaced plug and turned the engine over again it was cranking over but not really trying to start.
Is there a chance I did some damage there?
I have now replaced all the plugs and leads but car still won't start. It turns over fine (no strange noises) but won't actually start up. I don't have a torque wrench so I have guessed tightening the spark plugs based on how tight they were when I took them out, would that make a difference? I haven't replaced either of the coils yet, but I was hoping to avoid that cost if possible.
Any help with possible reasons why car is now not starting would be very, very welcome.
Cheryl
Is there a chance you dropped something in the plug hole?
Have you plugged all coil wires in correctly?
Did you break a plug installing?
Is there spark from the coils (hard to test)?
The original issue could also been from Cam, Crank, O2 sensor fault as well as ignition components. Also, build-up of gunk/carbon in throttle body.
It might be time for you to get someone that knows what they are doing to look at it to help you.
Hi 2000Ignis, thank you for your reply.
Deffo nothing left in engine, all wires double checked and correct, plugs all still intact. I don't know about the coils.
What I don't understand is why the car was working (albeit not perfectly) until I removed and replaced one of the spark plugs the second time. It was fine the first time. Are there rookie mistakes for replacing spark plugs I could have made that might have caused the engine to make that odd noise and stop working?
The diagnosis for the original issue was made by a local mechanic I trust, although he could be wrong of course!
