Hi Everyone... This is great.. OK by now you know i'm new.
I own a Suzuki Every 1999 Model [imported from Japan]. Have been using this for about 3+ years now and have clocked about 20,000 kms. The only part I have replaced so far are the Sensors. My Tacometer reading has just exceeded 100,000 kms. I'am told that replacements are needed at this stage....
Could anyone please tell me if there is any preventive replacements/maintenance to do at this stage? And what are the items. :confused: Thanks
Hi there! Welcome to the Suzuki forum!:)
Wow! Tagal mo din napakinabangan. Does your van has aircon and how is it?
Where are you from? I guess your van is a rear engine? What do you mean ng sensors and saan ka nakabili? Syensa na sa mga tanong ko but kung hindi pa palyado at mausok I guess preventive maintenance lang ang kailangan mo at check mo gaskets, tune-up and change oil lang siguro.
I'm sure some of our members can answer your questions regarding this.
Check your van specs here:
Suzuki cars, all models (used, imported, new): pics, specs, performance
Hi Yellowturtle... appreciate the quick reply. I'am from Srilanka. Yes it has A/C and the engines under the front seats. Engine No is F6A- & Chasis is DA52V.
The sensor that was replaced was the CAM Sensor. Pls reply in English Thank You
Is your Every fuel injected?
If it came with an owners manual, there should be a list in there for all recommended maintenance items.
At 100,000 km, I would definately highly recommend a new timing belt. Also a cooling system flush and new coolant, changing the gear oil in the transmission and differential, and replace the brake fluid. Check all belts and hoses.
Larry.
Hi Larry.. Appreciate yr comments. Yes it is Fuel Injected. We do not have an agent here representing this make/model so its almost impossible to get Genuine Spares. Pls update me if you know of dealers in Singapore or Malaysia that sell the genuine spares for this model. And yes I do have an Owners Manual but its in Japanese so I wudn't mind knowing a place where I can get and English Copy. Thanks Marlon
I don't even know where to get parts HERE! For someone used to the US and getting parts there, trying to find parts in the Philippines is very frusterating. I know of noplace here in Dumaguete that stocks parts for the fuel injected models.
Good luck.
Larry.
