1 - 10 of 10 Posts
I have a 2016 Suzuki escudo(vitara) I had a bad cooling fan then after that and I started to get a heavy idle and a loss of power when reversing up inclines. It doesn't move at all but on flats it does reverse. I have replaced the cooling fan so far, the throttle body so far has been ruled out. Another problem is the car heat meter is a stroke or two above half which suggest the engine may be getting too hot. Can I get help?
Which engine and transmission
You have no drive at all?
And what is a heavy idle?
Have you determined if the head gasket is compromised ?
Take a look at the engine oil on the dipstick. Does it look like cream ? Also check the radiator cap (when the engine is cold).
Edited post, Sorry, already asked if it drives in all gears and not just reverse
It moves in all gears but in reverse on an incline the rpms don't go pass 1000 and it doesn't move. On a flat road it takes a while to catch
Accurate details are critical, especially since we are not there to see what is happening.
If you had a transmission related issue, the engine rpms would be going over 1000 rpm without the vehicle moving - the engine doesn't know whether the transmission is in drive or reverse - so, you would have to be experiencing come form of problem when trying to move forward, which I don't see any mention of.
What is your experience with motor vehicle repairs?
1 - 10 of 10 Posts
