The other easy way most of the time is just swap with a cylinder you are not having trouble with and see if the problem stays or follows the coil.
Also check the wiring for the coils and injectors as they are know to have insulation shrinkage and then shorting issues with the now exposed wire.
The Verona COPs are just a plain ignition coil with NO built-in ignitor, So, fire them just like any ignition coil with a 2-3ms dwell
Jan
