New to the forum... Been search for info on my problem but no go... Bought a 91 efi Sammy with lots of stuff done to it. Been running good but one day it died, but then it fired up again. Ran good for a week then cut out a bunch of times. So started searching on the net for solutions.. Things I've done so far...plugs, wires, cap, rotoe, Rebuilt computer (sent in for new copasitors), replaced coil, checked all the wiring harness, cleaned all grounds, put new grounds in, both relays by computer Have a friend with same unit, every time it quit I change distributor and pickup coil in it , used his ingniter ... I'm at a loss??? Would inj make it quit?? I let it sit , it fires up.. It's different every time... Any input would help... Thanks
That could be a fuel starvation problem, have you replaced the fuel filter?
I replaced everything... And I'm getting fuel but no spark when warm... I can go out an hr later and it fires up and runs good...
