I have a 2005 Suzuki Alto, with 36k miles on the clock , and I am not sure if it is normal.
When the car is first started it revs up to 2000 RPM, and takes around 5 or so minutes to go to normal Idle speed.
Any Ideas what it could be?
is it normal on car for its age?
sounds like the idle control system is functioning as it should, but initial revs may be a bit high.. Can be caused by many things. When you start it should immediately head to about 1500 to 1800 rpms depending on ambient temps then drop steadily over the next 5 minutes.
Has it just started doing this? or has it always done it?
