Has it got spark? No spark detection it won't fire the injectors.
Check for spark first then noid test the injectors
Why order new coils? Have you proved the no spark is caused by that? They aren't all going to fail at the same time. You need to start diagnosis and determine why it doesn't have spark.
If the cam sensor isn't telling the ecm the engine is turning, the ecm won't trigger spark or fuel.
Something as simple as a bad ground or power feed will do this.
Start testing.
