I put new bolts on the rear brake drum dust shield. To stop the corrosion that made taking the old ones out a real chore, I'm trying to come up with a method for protecting those bolts. Anyone have any idea's? I was thinking about just coating them with high temp grease. Putting a dab on each bolt head.
Any ideas would be appreciated.
For lug nuts, I've been using a mixture of wheel bearing grease and as much graphite as I can _reasonably_ mix in. I mix it in a 35mm plastic film cannister. The first batch lasted me 25 years, and I'm still on my second batch after about 6 years. A _VERY_ small dab on the first thread or two of the lug and the inside of the lug nut is all I use. I sometimes have to remove lug nuts on the road or trail, and I don't carry power tools. The grease helps exclude water, and should the grease evaporate, there are still solids left behind to lube the threads. It's rather like poor mans anti-seize compound, which would be my second recommendation.
I distinguish between high- and low-temperature applications, and use the anti-seize for the oxygen sensor, exhaust manifold, and muffler bolts. I suspect anti-seize would also work on brake parts. I've used brass/bronze bore brushes to clean out interior threads in steel. I believe that starting with clean surfaces is important.
Exposed bolt heads?
What about the bolt heads on the drum shield that are exposed? They always corroded badly.
If ultimate strength isn't a requirement, stainless steel is an option. Most stainless strength is a bit under US grade 5 (120,000 PSI), or it's metric equivalent, class 8.8, but above common steel, US grade 2 . Stainless tends to gall, so be sure to use anti-seize (or something) with stainless.
One metric hardware site that I found, mmsacc-stainless.com Metric Products, advertises its stainless at "85,000-90,000 P.S.I. Average Tensile Strength". Most common, low-strength metric stainless, A2-70 or A4-70, is around 100,000 psi.
ARP makes a good range of high-strength (metric class 10.9 = US grade 8) metric stainless (arp-bolts.com) and totallystainless.com carries most of them, plus some low strength SS (A2-70) as well. Be alert NOT to use common low-strength stainless where a medium or high-strength bolt is required.
