I've got an '88 with 33X12.5's and a trailer that is too narrow for it to fit on... I am thinking if I pickup an old stock set of rubber/wheels just for when it's on the trailer it may fit.
Can someone tell me what the actual, from outside of the tire to outside of the tire measurement is?
The width (edge to edge of the rubber) of my trail rig running 33x12.5 Swamper radials is 68". But I am also running a 2" wider custom axle so your overall should be 66".
Sorry, I now see my question wasn't clear.
What is the stock width, with stock tires & rims?
I have measured my rig as is, with the rubber is has on now, and I see it will not fit on the trailer as is. I need to find out what the width is with the stock rubber.
TIA
Here are some specs that are useful for you and interesting as well:
Curb Weight:___________________2,059 pounds
GVWR: _______________________2,923 pounds
Front Gross Axle Rating:__________1,257 pounds
Rear Gross Axle Rating: __________1,675 pounds
Max. Payload:___________________845 pounds
Max. Towing Capacity:___________1,000 pounds
Wheelbase:_____________________79.9 inches
Overall Length: _________________135.0 inches
Overall Width:__________________60.6 inches
Overall Height: _________________65.6 inches
Front Track Width: ______________51.2 inches
Rear Track Width:_______________51.6 inches
Ground Clearance:_______________8.1 inches
Seating Capacity:________________4
Front Head Room:_______________40.2 inches
Max. Front Leg Room: ___________38.3 inches
Rear Cargo Area Length:__________32.5 inches
Rear Cargo Area Width: __________50.0 inches
Rear Cargo Area Height:__________40.2 inches
Cargo Volume:__________________27.8 cubic feet
Interior Volume:_________________83.7 cubic feet
These are the stock specs. So add about 8" for the 2 stock tires (4" on the outside of the centerline of the tire on both sides) gets you just under 60" or just under 5'. I've personally seen stock sami's in the back of pickups but it is a tight fit.
