sheet??? what is that.? theres a bushing you need to replace in the tranfer case shifter and the transmission shifter.
Pull your shifter out again and make sure you have both notches in the center. Reinstall the shifter in the netural postion and see if something just didn't get out of line the last time. Also make sure the shifter bolt hasn't sheared off. It's the bolt that sticks through the housing and rides in the slot in the shifter ball to allow it to pivot.
Good work. The 'stuck shifter' (both trans and t-case) is one of the mandatory experiances we all go through owning and working on a 17+ yr old Zook.
The 'What the h*ll is a Shifter Sheet' question is another.
Welcome to the addiction.
