I want to know how to take off the steering wheel of my Ignis 2000……. Does anybody help me?
thanx
I beleive you want to know how to take off the steering wheel, well these following steps show you where and how to do it.
1.Remove the horn pad, and disconnect the horn button connectors
2.Remove the steering wheel lock nut.
3.After making alignment marks on the steering shaft and wheel, remove the steering wheel, using the Special Tool (09561-11002).
4.Remove the lower crash pad.
5.Remove the column shroud.
6.Disconnect the connectors.
7.Remove the multifunction switch.
8.Remove the bolt that couples the universal joint and pinion
9.After removing the bolts used to secure the column bracket to the frame, remove the steering column and shaft assembly.
Hope I will prove as helpful Professor for u.....bye
thanx
