1 - 20 of 22 Posts
Hey All,
So here is my problem, I am 6'-5" and so that I am not trying to drive with my knees around my ears, I have the seat all the way back, but with the seat that far back I find reaching for the wheel uncomfortable.:( Soooooo, is there any way, short of an aftermarket column that I can move the steering wheel back from the dash an inch or two?????
Thanks.
BTW it is a '92 2 door 4x4 auto JLX w/ tilt wheel
You could try to source an aftermarket steering wheel with a deeper dish or use a flatter aftermarket wheel and make a spacer to go between the wheel and the boss.
Thanks Rhinoman! For some reason that thought just never entered my brain. I was too busy trying to figure out how I could move the whole column. I already have the parts lined up. Grant makes an adapter and a cheap wheel that doesn't look too "cheap".
All the best!
steering wheel
Hi lurch zuki, I have the same problem with legs, 6-3 mostly legs,,,how did the grant wheel swap work out? I have a 87 zuki that is new to me,,one week. This is the first problem I need to solve,and asap. Thanks GRAYMAN SPOTTER
Grayman,
It didn't work out all that well actually... the wheel Grant wheel I got has a 3" dish, what I didn't take into account is that the stock wheel from where it mounts to the column is actually about 3 1/2" to 4" deep. The only saving grace for me was that the Grant is a little bit smaller diameter, so I was able to tilt it a little more vertical which brought it a bit closer to reach. I am still toying with the idea of having a machine shop make an extension to go between the Grant adapter, and wheel to bring it closer to me.
If you want I could take a couple of pics to show you what the Grant set up looks like installed...
Lurch
REPLY Steering wheel
Lurch, Thanks so much for the reply! Pictures would be great! Again I am on this fast so I can drive it comfortably, Just saw a site about "andys steering hubs",,specific to zukis, with a bit more time I am going to call them and see what they know.
Grayman
LURCHZUKI,
Well i made a couple of calls, Andys was a dead end. Andy's sugessted 101carparts.com,,,dead end. Then they suggested "Danner?",,,, could not find them.
Even and inch or so would be helpful.
The other thing I am considering is shortening up the clutch pedal pad abit, not alot of room to get up on the clutch in a hurry if needed ( part of the same problem, left leg and knee room).
wow im 6-3 and must have monkey arms cause i put my seat all the way back and can reach the wheel. you should b able to get an adapter made from the grant one just 3-4" thick.
I am not as tall as you guys, but all legs - 36" inseam on pants. With the seat all the way back, I have little problem reaching the steering wheel - I find that by adjusting the reclining seat back, I can get a comfortable position. ??
Lurchzuki - trying stacking a momo hub, with a momo~grant adapter and then the grant wheel.
Most of the Momo wheels are flat or near flat, so the Momo hub spaces the wheel away from the column by 2~3" - I've never really measured it, but for me it puts the wheel rim at the right position relative to the wiper/turn signal control stalks - add that to the disk on a Grant wheel and you'll get a few more inches.
FORDEM, Brilliant! I had not thought of that, I thought I was going to spend a bunch of time at the lathe to make a stand off/spacer. I think you have solved my problem! thanks much!
For the record, you can see I am new to this forum and I know that I have been comparing apples to oranges a bit cuz I have a 87 samirai and you guys appear to have a list of different zukis. BUT, by kicking around the idea, I got what I needed, thanks again!
SO, for the future, can you point me in the right direction for the guys that are specific to Samurai's, I must have missed that tab on the home page.
Additionally for BEX and deeznuts77,,, that apples and oranges thang applies,,sorry if I wasn't clear off the start.
GRAYMAN SPOTTER
Discussion Starter #14
Fordem,
That sounds like a perfect solution!!!! THANKS!!! I have been dealing with the Grant wheel where it is just because it is a bit smaller diameter.... gives me a bit more left knee room for the clutch.But it a bit close to the turn signal/ wiper arms. Actually very difficult to use the cruise buttons. have to stab at them through the steering wheel :(
I live in a pretty small little out in the middle of nowhere town, any ideas on the part numbers for the pieces you are referring to?? Where to get them online??
The Momo hub adapter to fit a Suzuki is Momo P/n 8904, and as far as I can tell, the Grant to Momo adapter is Grant P/n 4008 - be very careful with this last item - because they come in two forms, Momo wheel on Grant hub, and Grant wheel on a Momo hub, you want the one that takes a Grant wheel.
update
Thanks for the pictures,,,well i am onto a different solution to this steering issue ,,,it is to easy!!
Grant makes a 2 inch extention to stack on top of the adapter.
So the adapter is about 25 bucks, the extention was actually a bit more than that, but the parts guy i dealt with showed the extention had been in stock for a couple of years so he discounted that to me for 25 bucks and then I found a steering wheel i liked for 51 bucks, its the formula 4, 4 spoke, its 14 inches in diameter, there were not many choices in the 15 inch range.
I am a little worried about the lack of leverage with a 14 inch wheel.
anyway, for this project i am really trying to keep it cheap so all of the above is looking good, you guys have any ideas, or if I am on the wrong track?
GRAYMAN SPOTTER
to lurchzuki
hey lurchzuki, how did the last adaptor idea from fordem work out for you??? ,,also did you know about the grant extention I found out about,,and mentioned in my last post?
That may be the easiest solution for you eh? if you need the part number, I will have it in my hand tomorrow.
Grayman Spotter
Discussion Starter #20
grayman,
the momo idea sounded good but it doesn't appear to be street legal (the fuz up here are pretty particular about that kind of thing) and I also had trouble trying to find it online for a decent price... so i was just going to go with my original thought about machining a spacer. that was until i just read your post about the grant spacer... :)
would love to get the part number from ya.
1 - 20 of 22 Posts
