I'd like to know how much clearance you guys got between your steering column and wheel well/body work. Mine seems to be rubbing slightly. I'd like to know if this is a result of a bent column or worse yet a bent frame.
The part that's rubbing is the lower column i think it's called (ribbed looking thing).
So if any one could take a quick look at theirs or better yet a pic, it would give me a good idea
thanks.
Do you have a body lift or no?
With my body lift, it barely touches.
Discussion Starter · #3 · (Edited)
i honestly don't know...saw some rubber doughnuts between frame and body but those seemed to be OEM installed. Any idea on ground clearance and/or measurements I can take to confirm? FWIW it does seem slightly taller than others.
edit: just double checked following these guy's measurements http://www.pirate4x4.com/forum/suzuki/444978-4-door-sidekick-buildup-cool-daily-driver.html and seems like I don't have any lift. Should it be anywhere near close to rubbing on stock specs? Doesn't seem likely.
The rubber is stock.
