my suzuki jimny takes a while to start. it runs ok when started. the engine light is always on. has anyone any ideas how i can solve the problem?
engine light
this cars have the engine check light to warn you when the oxigen sensor must be replaced in my case it's a 88 samurai after you replace the oxigen sensor or if you just want to turn it off check under the dashboard on the driverside if it is anything like mine you'll find a little switch if so change it's position and that would do the job:lol:
