Hi,
Which terminal on the solenoid is the positive one? There are two terminals that are exactly the same size. and one little spade connection. There is a a small square connector with a hole in it that is attached to the starter. Which terminal does this go to? Can the positive and negative from the battery connect directly to these terminals? I am working on a 02 Samurai. Thanks for the help.
Jaime
Hello. Log on to the Suzuki Download site and grab one of the many free shop manuals available. You'll be glad you did!
In the mean time, the spade connector goes to the ignition switch circuit (actually, goes to the clutch safety switch first), the top bolt goes to the B+ (positive battery terminal, while the lower bolt connects to the starter (ground)
Good luck!
