So recently my GV had an encounter with some water (got water up to the top of the brake pedal lol). After getting it dried out, cleaned up, replaced a few O2 sensors, new battery (needed one before hand) im now having an issue starting it. I can go to turn the key and I will hear what I assume is the starter soleniod click then a second or 2 later the starter will kick in and it starts right up. Sometimes I hit the key and hear a rapid clicking coming from under the dash like where the fuse box or something is then it stops and starts right up. Any Idea what it is?? Starter, Solenoid, Relay????
Check the main and fuel relays, then do a comprehensive maintenance sweep of all electrical connections, hot and grounds...
.... Philip
.... Philip
Finally found a relay with some corrosion on it and in the socket. Cleaned it and the socket best I could and it seems to have fixed it but only time will tell. And I cant for the life of me find a diagram or something to tell me what relay it is.
