Looking for a spare alloy rim for a 1998 SQ420 GV.
I have 4 and need a spare.
The ones I have are marked as-
JWL, Suzuki, SMCV-670, 16X7JJ, OFF 5, TA (27/E1), TD (98/7), ENKEI.
These came from a local wrecker and were off a luxury 98 GV.
Also wanted to know, are the wheel nuts the same from the standard GV Steel rims to the alloys?
Were originally a golden colour between the spokes on the inlay but I have now stripped the rims back to bare alloy.
Haven't installed these yet as have only just finished cleaning them up.
Located Muswellbrook 2333, Hunter Valley, NSW Australia.
That wheel is made by Enkei, not Suzi. You should be able to get one thru your local tire guys.
Thanks, I agree it is an Enkei though as it is cast with the Suzuki name into its internal face I am guessing it was manufactured by Enkei for Suzuki.
Yes, Suzuki uses the same lug nuts on both the alloy and steel wheels.
In a nutshell you match the lug nuts to the wheels - look at the lug nut "seats" on the alloy wheels - if they have a flat surface, they require a shanked nut with a washer, if they have a tapered seat, they require a nut with a matching taper.
