Hi folks
I have recently installed the wiring for a split charging system in my 1998 diesel Vitara and have used a 40amp relay in the process. I have connected the pins on the relay as follows:
Connector 85 = chassis earth
Connector 86 = Relay switch - wire from warning light/alternator
Connector 87 = charge to battery 2 (currently only a wire running to the boot - battery yet to be installed)
Connector 30 = charge feed from alternator
I have all of the above in place, however when I measure the voltage from Pin 87 it reads a constant 12volts until the engine is switched on where the voltage increases to 14Volts - this does not seem correct as I would have thought that this pin should read 0Volts when the engine is off, am I correct? It would seem that perhaps there is a faulty relay involved?
Many thanks
Jay
Sounds like a bad relay to me. The voltage seems fine, but there definitely shouldn't be any with out supplied power to pin 85 or 86.
Do you have voltage on pin 86 of the relay before you switch on the engine?
