1 - 20 of 20 Posts
guys, any suggestions on the brand and type of spark plug to use on my F6A? How long before we need to replace them? Thanks in advance!
good day! i drive suzuki super carry 4 cylinder 8 valve 1000cc model 2000. according to my owners manual periodic maintenance schedule replacement of spark plug every 10 thousans kilometers or as needed. ever since i used bosch platinum. i don't know if there is available for F6A engine, mine is F10A and we have been together for almost 8 years. hope this help. if you wanna see my my suzi the name of carry. try visit my garage. God Bless
LF:uzuki super carry 4 cylinder 8 valve 1000cc
haloo,
i'm looking for uzuki super carry 4 cylinder 8 valve 1000cc.
any help pls.
Sir try at the commonwealth avenue near SM fairview. Or in marikina area, conncepcion area. Or lastly near near araneta ave. N domingo beside Banco De Oro.
Junver, I just had my denso spark plug (probably OEM) replaced with Bosch Copper. Is there much of a difference in performance if you use platinum plugs, even if you perform periodic replacement? How much does each Platinum plug cost?
sorry for the late reply, here in tacloban php155.00 bosch platinum if you canfind original champion brand made fideral mugol. much better but i don't know if there is available now a days in the stores coz mostly they sell imitation. for my carry every 6 months i replace all my spark plugs and change my oil. by the way i using mobil 1 with supersyn technology 100% fully synthetic.
NGK IX iridium linkNGK.com - Vehicle Fitting Results
list of engine model fit to ngk spark plug
nGK Spark plug DCPR7EIX Box of 4
This is a box of 4 spark plugs
Iridium IX plug, 12mm, 3/4" reach, 5/8" hex, gasket seat, resistor, projected tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, SOLID TERMINAL TOP
will fit to this list of engine
SUZUKI ALTO 1988.9 - 1990.3 550 (4VALVES) F5B
SUZUKI ALTO 1990.3 - 1991.9 660 (4VALVES?DOHC) F6A
SUZUKI ALTO 1990.3 - 1991.9 660 (4VALVES?DOHCTURBO) F6A
SUZUKI ALTO 1990.3 - 1994.11 660 (4VALVES) F6A
SUZUKI ALTO 1991.9 - 1994.11 660 (4VALVES) F6A
SUZUKI ALTO 1991.9 - 1994.11 660 (4VALVES?DOHCTURBO) F6A
SUZUKI ALTO 1994.11 - 1998.10 660 (4VALVES) F6A
SUZUKI ALTO 1994.11 - 1998.10 660 (4VALVES?DOHCTURBO) K6A
SUZUKI ALTO 1998.10 660 (4VALVES?DOHC) K6A
SUZUKI ALTO 1998.10 660 (4VALVES?DOHCTURBO) K6A
SUZUKI ALTO 1998.10 660 (4VALVES?EP?) F6A
SUZUKI ALTO 1998.10 660 LEAN BURN K6A
SUZUKI ALTO 1999.10 660 (4VALVES?EP?) F6A
SUZUKI ALTO 2000.12 660 (DOHC) K6A
SUZUKI ALTO 2001.4 660 LEAN BURN K6A
SUZUKI ALTO LAPIN 2002.1 660 (DOHC) K6A
SUZUKI ALTO LAPIN 2002.10 660 (DOHC.TURBO) K6A
SUZUKI CAPPUCCINO 1991.11 - 1995.5 660 TURBO F6A
SUZUKI CAPPUCCINO 1995.5 - 1998.10 660 TURBO K6A
SUZUKI CARA 1993.1 660 (DOHC) F6A
SUZUKI CARRY 1988.2 - 1989.5 550 (3VALVES?SUPERCHARGER? F5A
SUZUKI CARRY 1989.5 - 1990.3 550 (4VALVES) F5B
SUZUKI CARRY 1990.3 - 1991.9 660 (4VALVES) F6A
SUZUKI CARRY 1991.9 - 1999.1 660 (4VALVES) F6A
SUZUKI CARRY 1999.1 - 2001.9 660 (4VALVES) F6A
SUZUKI CARRY 2001.9 660 (4VALVES?DOHC) K6A
SUZUKI CERVO 1988.1 - 1990.7 550 (4VALVES) F5B
SUZUKI CERVO MODE/CERVO C 1990.11 - 1998.10 660 (4VALVES) F6A
SUZUKI CERVO MODE/CERVO C 1990.7 - 1998.10 660 (4VALVES?DOHCTURBO) F6B
SUZUKI EVERY 1987.8 - 1989.5 550 (3VALVES) F5A
SUZUKI EVERY 1989.5 - 1990.3 550 (4VALVES) F5B
SUZUKI EVERY 1990.3 - 1999.1 660 (4VALVES) F6A
SUZUKI EVERY 1991.9 - 1999.1 660 (4VALVES) F6A
SUZUKI EVERY 1999.1 - 2001.8 660 (4VALVES) F6A
SUZUKI EVERY 2001.9 660 (4VALVES?DOHC) K6A
SUZUKI EVERY 2001.9 660 (4VALVES?DOHCTURBO) K6A
SUZUKI EVERY WAGON 2001.9 660 (4VALVES?DOHC) K6A
SUZUKI EVERY WAGON 2001.9 660 (4VALVES?DOHCTURBO) K6A
SUZUKI FRONTE 1988.9 - 1989.4 550 (4VALVES) F5B
SUZUKI JIMNY 1995.11 - 1998.10 660 (4VALVES?TURBO) K6A
SUZUKI JIMNY 1998.10 660 (DOHC.TURBO) K6A
SUZUKI Kei 1998.10 660 (4VALVES?DOHC) K6A
SUZUKI Kei 1998.10 660 (4VALVES?DOHCTURBO) K6A
SUZUKI Kei 2001.11 660 (4VALVES?DOHC) K6A
SUZUKI Kei 2001.12 660 (4VALVES?DOHC) K6A
SUZUKI Kei 2001.12 660 (4VALVES?DOHCTURBO) K6A
SUZUKI Kei 2001.4 660 (4VALVES?DOHC) K6A
SUZUKI Kei 2001.4 660 (4VALVES?DOHCTURBO) K6A
SUZUKI MOCO 2002.4 660 (4VALVES?DOHC) K6A
SUZUKI MOCO 2002.4 660 (4VALVES?DOHCTURBO) K6A
SUZUKI WAGON R 1993.9 - 1998.10 660 (4VALVES) F6A
SUZUKI WAGON R 1997.11 - 1998.10 660 - K6A
SUZUKI WAGON R 1997.4 - 1998.10 660 (4VALVES) K6A
SUZUKI WAGON R 1997.4 - 1998.10 660 (4VALVES?TURBO) K6A
Suzuki Wagon R 1998 - on 1.0L K10A
SUZUKI WAGON R 1998.10 - 1999.10 660 (4VALVES) F6A
SUZUKI WAGON R 1998.10 - 2000.12 660 (4VALVES) K6A
SUZUKI WAGON R 1998.10 - 2000.12 660 (DOHC.TURBO) K6A
SUZUKI WAGON R 2000.12 660 (DOHC) K6A
SUZUKI WAGON R 2000.12 660 (DOHC.TURBO) K6A
SUZUKI WAGON R PLUS 1999.5 1000 (DOHC) K10A
SUZUKI WAGON R PLUS 1999.5 1000 (DOHC.TURBO) K10A
SUZUKI WAGON R SOLIO 2000.12 1000 (DOHC) K10A
SUZUKI WAGON R WIDE 1997.2 - 1999.5 1000 (DOHC) K10A
SUZUKI WAGON R WIDE 1997.2 - 1999.5 1000 (DOHC.TURBO) K10A
denso spark plug for suzuki carry is good,but if u can use a Bosch which is made in Germany is better (cos there is also a Bosch spark plugs which is China made,they are the same in appearance but there is a diff in performance). r u from bacolod?if ul going to ask abt the spark plugs,in different auto stores in bacolod,they will prefer denso or bosch (copper). ur air-fuel mixture will also affects the performance and lifespan of ur spark plugs.
good evening,
how do you remove spark plugs of your carry pick up type?
are there special tools needed?
newbie here, i find them hard to remove due to the location of the plugs.
any help would be appreciated.
thanks.
i used the spark plug wrench which is the same i think in the 125 motorcycle,as long as it is the same size w/ ur spark plugs,then the back of another spark plug wrench which has a hexagon that can be fitted to the back hexagon whole of ur small spark plug wrench then use an adjustable wrench for it to be tighten or lossen,its a cmbination of two spark plug wrenches i am using but the other one is for the purpose for being an extension for the wrench.
for a suzuki carry pick up type its difficult to remove the spark plug on the third cylinder if u will use a long spark plug wrench.
Banned
Guys, i just wanna know your opinion.
My 12 Valve Suzuki Mini Van got a new and Installed Carburator, Engine sound is so smooth but what worry me is , a water coming out at the exhaust.
What is this mean?
i have also suzuki kei with 6ka engine, my car running is 98000 km but it still no need to change plugs. it is factory fitted titanium plugs which will run 300000km approximately. u should use this kind of titannium plugs.
does anybody know the spark plug gap for F6A 3 cyl /carb engine?
I set my plugs at 28th that seems a good gap for my engine just try a few different setting till you get it right you will know as the engine will have alot more power then when you go to fare the wrong way it will lose power i started at 30th then worked closer ie 30th,28th,26th but 28 was the best for my engine best starting and economy. I get 13kpl arround town and 19kpl on a trip I do not know how any one dose and would be interested to here.
What is this mean?
Good for your rig, your exchaust pipe spews small amount of water in the morning when you first start your engine, but if it is a large amount and there is a mixture of oil in your radiator, thats a different story.
1 - 20 of 20 Posts
