gud day....i just want to ask some tips on how to clean the inside of the fuel tank...i've found out that there are small rust deposits...ive already drained the gasoline and washed the fuel tank with soap and water...what should i do and how can i eliminate the rust deposit inside the fuel tank...need some advice...thanks...
Find a small aircraft maintenance facility or a classic car restorer in your neck of the woods - they should both have access to what is termed "sloshing sealer" a chemical that is used to coat the inside of the tank to prevent rusting.
You can probably find a kit on the internet and do it yourself, but my preference is to leave this particular task to the professionals.
sir FORDEM..thanks for the info...ill try to ask for the sloshing sealer in an aircraft facility nearby...for now, i just replaced my fuel filter to prevent rust from entering the carburator...:)
