I am fairly mechanically deficient so please bare with me! I have a 1982 Suzuki SJ410 and wanted to get some 1.5" wheel spacers for my rig. My Zuk is stock, but I am planning to put a 5" lift kit on the car and some 31" tire to go with the lift.
My question is will the wheel spacers that fit on a Suzuki Samuria fit on to my car? If not what size should I look for? Also what types of spacers do you recommend.
Thanks for the help!
P.S. this is my first post.
5" Suspension System tire and rim recommendations"
Tire size 31" x 11.5
Rim size 15 x 7 or 15 x 8 with 3.25" - 3.6 Backspacing
Stock front bumper tube removed. If minor body rubbing occurs ten add body lift.
Call CALMINI for more info
Thanks John
John thank you for your message!
This is the exact same set up I'm thinking of getting, 31" tires with 15 x 7 rims with my 5" Calmini lift. I wanted to add some 1.5" wheel spacer on the SJ410. I can only find the 5x5.5 that fit on a samurai, will these also fit the SJ410?
Spacers for the Samurai will fit the 410 as well. You will need to consider gearing as well, its going to be very slow on stock gearing.
Thanks Rhinoman for the info! I ll start looking for the spacers. After I m done with lifting the SJ I was thinking of an engine swap (vitara 1.6 16v w/ suzuki samurai transmission.
