hi guys...im new here..great forum;)
so...i have an sj410 '84 f10a carb engine with 4spd manual.
im going to swap engine with a g13bb 16v sohc from later sams.I can get the 5spd gears from the same engine but no the wiring and ecm:(
I found the complete wiring loom and ecm from a jimny'99 with the same g13bb 16v sohc.Do they mate together or my engine wont be compatible with the ecm and wiring:confused:I also need fuel pump right:confused:
Please someone inform me because i am one click before buying them.
Why not just throw Any Hyundai Pony Car Carb on that engine you have installed allready . There cheap from any junk yard and they Bolt right up and you'll gain like 15hp i did it on my 84 and it Ran like brand new
i dont have that option because of my 4speed gears.they are ok on the mountain but on a trip in highway are terrible,so high rpm for 100km/h.and the carb upgrade will be a very bad option with that rpms for fuel.
Ok then, get a 86 and use the hyundai carb, they have 5 speeds and are No speed demon but they go allright on the highway... Is there any lift in that sammi as if there is i woulden;t wanna go any faster then 100km anyways....
cheers
84 stack springs with 86 springs Togeather combined with with Spoa you can fit 37's on those zukis also
no is stock height.future upgrade with ome springs 2inch lift only.so im going g13bb 16v and i cross my fingers..thanks guys!
