Hi all, I have a 91 sierra which I have fitted 2 inch lifted EFS springs and Rancho shocks. Since I have fitted this suspension the car is almost 2 inches lower on the drivers side. The front and back shackles are both pushed out on the drivers side and are almost vertical on the passenger side. I have tried swapping the springs from side to side but with no luck. Has this happened on other Sierra's or just mine? Could the chassis be twisted? If so how can I check that?
It is quite common although yours does sound like its worse than others. First off have you checked that the shocks are moving freely up and down? are the brake lines loose? The chassis could be twisted, its worth getting it checked if you can't find any other issue
