hello guys! i'm new here.
i have a problem with my suzuki carry ride.
maybe you can give me some diagnosis on what's my problem.
every time im idling, my engine shakes and when i turn on my a/c even more shakes occur. also when i rev up the engine, stronger shakes will appear. if i also engage in first gear and starts to run, shakes also would occur.
what do you think is the problem?
i encountered this similar type of problem a few months ago and got it repaired. i replaced the spark plugs and the black cables connected to it. but the problem appeared again.
i don't know what to do.:confused: thanks in advance!
3 things you may need to check:
1. point gap (if your engine is with a distributor)
2. high tension cables - make sure none is loose both on spark plug ends and distributor end. replace if worn.
3. Proper carb fuel/air mixture.
thank you guys for the replies!:rolleyes:
got it fixed. i just had the spark plugs cleaned up. some carbon deposits have formed causing those shakes i felt.:D
Shaky engion
Greetings! WHY is carbon foweling your plugs so quick? How long since you changed the air filter?
Is the carb running rich? Just curious:D
