Hello Everyone,
Recently I bought a 2007, Suzuki Forenza, 115k miles which is my first car. The car looked pretty well maintained and firestone report indicated just a radiator hose replacement and some spark plug change.
About two days after I bought, the CEL was lit up. The person I bought it from is a firestone manager and I took it back to him and the codes pulled out indicated a misfire in cylinder 4 and O2 sensors. He agreed to replace all spark plugs and the wires. However the CEL turned off itself after that.
Even though it used to get lit up sometimes, and go off on its own, I did drive it for about 500 miles. I got a complete engine diagnostic done at Firestone and they suggested a head gasket valve replacement.
There was no oil leak before but later I am seeing some oil leak on the right side of the engine. I tried to get the head gasket valve but most of the auto parts store I contacted said they do not have it and needs to be ordered from the dealer.
Today the top radiator hose had a pin hole leak right at the place where it was clamped. The seller has agreed to replace that one for me. However there was not a bit of coolant in the reservoir for me to even drive it to his place. So I brought a clamp and cut the hose to the point where it had the hole and clamped it. I don't have the right set of tools so I can still see the coolant dripping occasionally from the same spot and the coolant level dropped to below minimum in half a day. So I am planning to top it up before I drive it to his place tomorrow.
Also regarding the CEL, I found that the fuel tank cap was not closing properly and so I changed it just today. Yet the CEL is still on.
Kindly advise if I have to replace the head cover valve (if so, is ordering from the dealer the only option?) and also since I could clearly see a leak in the hose, could that be the only problem why the coolant was getting drained or could there be another issue? I am on a tight budget and right now put everything I got on this car.
Thanks,
Deepak
Thanks,
Deepak
