Set of 4 Yokohama Geolandar I/T G072 Winter Tires 225/65/R17 mounted and balanced on Suzuki Grand Vitara OEM Alloy Rims (bolt pattern 5X114).
The tires and rims are Made in Japan and the tires were slightly used for 1 season.
http://www.yokohamatire.com/tires/geolandar_GO72.aspx
http://www.yokohamatire.com/tires/ig_20_geolandar_it.pdf
Yokohama Geolandar i/t G072:
• Two compound elements combine to eliminate the thin film of water that causes slipping.
• Absorptive carbon flakes use capillary action to draw water away from the surface.
• Shelled microbubbles absorb any remaining water & improve contact with the ice and snow surface.
• As the tire rotates, the water is expelled, prepared for its next contact with the road surface.
• The silica with eruma agent compound enhances tire tread flexibility in very cold conditions, enabling it to grip the road.
• 3-D pyramid-shaped sipes interlock to maintain strong tread blocks, improving block stiffness during acceleration, braking & cornering. Multiple edges offer better grip & control.
• Multi-flat profile expands the contact area of the tread on the road surface & allows for wider grooves to expel water, snow & slush. It also reduces tread noise & irregular wear.
• Power edge blocks equalize contact pressure under heavy loads, for increased stability & reduced irregular wear.
• Reverse `V' shaped centre blocks evacuate water effectively from the centre of the tread under braking.
$990 OBO
