1 - 9 of 9 Posts
just got a 92 samurai, it will start if I put fuel down the tbi.
will only run until fuel runs out.
installed new fuel pump & filter, tried different ecm from a buddy.
anyone have any ideas or suggestions?
Here's a thought or two:
1) Check fuel pump relay if you have one
2) Was the ecm from the same type of transmission? Manual ECM different from Automatic ECM...
maybe I should have mention this is a samurai.
new fuel pump works fine have gas right up to the tbi.
ecm came from 91 samurai so it is the same as my 92
oops....you're right...Samurai different from Sidekick...sorry....just trying to help.
Have you tried pulling codes while cranking? the ECU looks for a feedback signal from the ignition and if it doesn't see it it will cut fueling.
I have check engines with fuse in service slot in fuse panel with ignition on, it give engine code 12 which means everything is normal.
didn't know you could check codes when cranking?
Cam sensor codes only show while cranking. Have you got a noid light? you should check the the injector is receiving a signal from the ECU.
The camshaft sensor but you have spark so that should be OK. Did you check the codes while cranking? if that still shows OK then its probably a faulty ECU.
1 - 9 of 9 Posts
